Cecilt wrote:
Tachdriver wrote:
I had the sidekick grill with a QD adaptor connected to a hose which was QD'ed to the trailer fitting.
My TT had the two bottles, the regulator going to the QD fitting. When I replaced the grill I removed the fitting from the sidekick and installed it on the weber, and yes I had to remove the regulator, it works and is hot as I need it.
If you have a class "A" or "C" you may need other fittings that I am not familiar with.
Others mentioned getting a small propane bottle but that defeats the purpose of using your 60-150 pounds of propane you are carrying around. Too bad I didn't take pictures.
This sounds like the plan. I currently have the quick connect attached to the propone hose that I pull out of the TT wall to connect to my Sunbeam Sidekick grill. So all I have to do is remove the male fitting from the Sidekick, remove the regulator from the Weber and screw the male connector onto the Weber and call it a day??? Sounds too easy? Have to missing something or more importantly a part. If so, I'll pick up a stand for the Weber and I'll be good to go.
This will do the trick. Since you already have the fitting from the Sidekick you don't need to buy anything (except the stand if desired).
