Raife's avatar
Raife
valve stems for TPMS
Good afternoon everyone. So I have been doing research (and posting questions on forums) regarding getting a TPMS for my trailer. I have settled on the TST 507 system, but am now wondering if it is worth the cost of getting the rubber valve stems replaced with metal ones to use the flow thru sensors? To have a single display and more info I am also considering have the tow vehicle done as well (even thought it already has a TPMS built in, but only shows current PSI). The cost to swap out the trailer valves is ~$70 and the tow vehicle valves is ~$130.
All said and done I'm looking at 10 tires as I figure I would want to know the status of spares as well (at least to know they are full - my TV spare was down 15 PSI the other day, but it had not been checked in a while)
Thoughts on swapping out the rubber valve stems for metal?
Does anyone have experience with both the cap and flow thru? Are the flow thru that much more convenient to warrant the cost of swapping out the rubber valve stems with metal?
Thank you.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: Apr 08, 2026
