Raife's avatar
Raife
valve stems for TPMS
Good afternoon everyone. So I have been doing research (and posting questions on forums) regarding getting a TPMS for my trailer. I have settled on the TST 507 system, but am now wondering if it is worth the cost of getting the rubber valve stems replaced with metal ones to use the flow thru sensors? To have a single display and more info I am also considering have the tow vehicle done as well (even thought it already has a TPMS built in, but only shows current PSI). The cost to swap out the trailer valves is ~$70 and the tow vehicle valves is ~$130.
All said and done I'm looking at 10 tires as I figure I would want to know the status of spares as well (at least to know they are full - my TV spare was down 15 PSI the other day, but it had not been checked in a while)
Thoughts on swapping out the rubber valve stems for metal?
Does anyone have experience with both the cap and flow thru? Are the flow thru that much more convenient to warrant the cost of swapping out the rubber valve stems with metal?
Thank you.
  • Ditto those that said get metal valve stems regardless of what type of TPMS you get. From what I've read the rubber stems will not hold up over the long haul and you'll start getting pressure loss through them. This is what has held me back from getting a TPMS for my trailer. I won't do it until I can get the valve stems changed from rubber to metal.
  • Actually - followup...has anyone hardwired the unit to an ignition-switched fuse in the TV fusebox?
  • I second the not purchasing the flow through senders, and going with the regular sender caps. And would not spend the money for the tow vehicle added senders, just the trailer. But I would remove the rubber stems and replace with metal stems for the security of having them not flex and possible snap off with the sensor on the end of the rubber.
  • The metal valve stems are a good idea regardless of which TPMS you get. But IMO, and I have the flow-through sensors, save your money on the flow-through sensors. You'll find yourself removing them to add air. The restriction is so great that it takes quite a long time to add just 5 psi. If I did it again, I would get the regular sensors and skip the flow-throughs.
