ktmrfs wrote:
JBarca:
good info that seems to shed light on the changing recomendations.
I'll also add my experience related to 4 people I've helped set up a WD hitch. This was after they complained to me that they felt the trailer was giving them sway and didn't feel comfortable with the way the combo handled.
In each case looking at front "rise" measurements and rear "Sag" measurments I found that the front was always high compared to unloaded and not bringing the front back to even 1/2 the difference. Once I adjusted the setup to bring the front back to at least half or more of the distance (I was shooting for close to unloaded) the problems went away and they were amazed at the difference in handling.
At the time my thought was that with the front end rising they were getting more camber on the front axle which coupled with a lighter front end, heavy back end was letting the front end be to sensitive to steering correction.
Yes, in the extreme it would probably oversteer rather then understeer.
My conclusion after helping all the folks I did adjustment for was to keep increasing front load (dropping the front) till the wander problem disapeared. it seem to take bringing it back to at least 1/2 the difference to be effective.
Now all this was done on smaller lighter vehicles, <1/2 ton trucks, Suburbans etc.
Hi ktmrsf,
By chance were your friends who you helped, first time TT owners, or their first time using or adjusting a WD hitch?
Yes, I agree, many first time TT owners, never had some one explain to them or did they understand what a WD hitch is supposed to do. The dealer setup the tow rig with an empty trailer, and many times, an empty truck and down the road the new owner goes.
Then the new TT owner, loads the camper and the truck. The TT tongue weight changes, the truck suspension changes, yet the WD settings are left from an empty camper.
Then there is the misunderstanding on how to hitch up when using a WD hitch and how to use the trailer tongue jack to lift the camper way up, then snap up the WD bars.
This adds up to, the new owner thinking, wow these WD bars are really tight, they for sure do not need any more adjustment. And they end up with the front end of the truck being very light and the rear axle, very heavy. The truck handling is bad, and having a lighter truck can make it all that much worse as the the lighter truck really needs the benefit of a WD hitch adjusted correctly.
Close to the same thing above happened to me on my first TT. While I had towed many trailers, open deck, sail boat, enclosed cargo trailers, I never towed a TT needing a WD hitch. So I asked the shop PDI person, what do I need to understand or do to adjust this WD hitch? He stated, just take up a link if you want to move more weight. They wanted to explain more on how to work the appliances inside the camper then a WD hitch or trailer running gear. I was green enough then to not ask further when, why and how do you know what to adjust on a WD hitch? Then the learning started. My one year old 2002 1/2 ton Tahoe was out of cargo capacity the day I filled the camper with cargo. And the 800# WD bars the dealer gave me on an 800# dry tongue weight camper were also, very wrong even after I stated, are you sure I do not need the 1,200# bars? He said no, I would not send you down the road with a miss matched setup.
When I got home and started loading the camper, I realized my mistake as tow ratings are very misunderstood if the truck can't handle the loaded tongue weight of a TT. Before I got myself into an bad situation, I fixed the weight issue changing the truck to a 2003 K2500 Suburban and then even more learning started.. GM torsion bar front ends will not drop once the yellow jounce bumpers hit. I have always said, you learn a lot more when things go wrong...
It too have since helped many, many fellow camping friends understand the same error of my ways and adjusted them back into a very stable towing setup. Some though had to change the truck too.
Point: It is common to have handling issues from the WD hitch being very out of adjustment. And the WD hitch is only one of many factors in a stable towing rig. But it starts with proper TW on the camper, then proper WD adjustment, then comes all the other factors, tire pressures, trailer towing stance, is the truck overloaded and the list goes on.
Experience is something that is learned, over time, you are not born with it. :)
