garyemunson
Dec 18, 2019Explorer II
I found on my furnace the rubber gas line was long enough to reach outside to sawhorses I had the furnace on once I removed it. I bought a 4 prong trailer light plug and connected that into the furnace wiring to make unhooking easier. Now I can unplug/disconnect, remove furnace, place it on the sawhorses, reconnect and easily see it work. While I had it out, I lined the intake air plenum chamber area with automotive underhood sound deadening mats and considerably reduced the noise of the furnace.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
