BillyandKris's avatar
BillyandKris
Vinegar and baking soda in holding tanks?
Forgive me: Age-old subject beat to pieces! We have used strong vinegar to clean our holding tanks before and get gauges working. Have heard others mention using vinegar AND baking soda. We know how much vinegar to use, but how much baking soda? Have tried filtering through some forum posts and there is so much chat and going off subject that I have been unable to determine baking soda amount. Have used vinegar/baking soda down drains to clean out and it does that “boiling” thing. We are trying to clean off HARD WATER DEPOSIT AND SOAP SCUM BUILD-UP only. Not worried about other “stuff” as that is not the problem for us. Think we run into these issues from sitting still for long periods with hard water source and no sloshing/cleaning effect. Thanks for advice.
  • Put about 10 boxes of baking soda in the tank ... then pour about 4 gallons of vinegar into it. Call me when you do this as I want to watch . . . from a distance! :^)
  • DrewE's avatar
    DrewE
    Explorer III
    Baking soda and vinegar react to produce carbon dioxide and sodium acetate in solution. The carbon dioxide has no real cleaning benefit (though dissolved in water it is acidic, which may help very slightly with some mineral deposits), and sodium acetate is also so far as I know not a particularly effective cleaner, though it does have some other industrial and commercial uses.
    Plain baking soda is useful as a cleaner mainly in being a mild abrasive that is soft enough to not harm many surfaces. Vinegar is useful do to its acidity mainly. Neither one is especially effective against soils and general dirt (if you aren't actively scrubbing). Laundry detergent or dishwasher detergent and a lot of water would be more effective than either, in my estimation. Scrubbing with a brush would also work very nicely, but is very rarely practical and probably never pleasant for a holding tank.
  • I also use the Calgon and laundry detergent method - I use the HE detergent so that it doesn't foam up.
  • ^ 2 cups Calgon along with a 1 cup of laundry detergent. That will make your tank sparkle.
  • Oh, RIGHT. I think I heard that before!! GADS, thanks for pointing that out about baking soda. Will skip that part.
  • Baking soda will neutralize the acid(vinegar), that will defeat the purpose of dissolving the hard water scale.
  • I think that combination mostly produces a "gee whiz" effect.
    The "boiling action" is from carbon dioxide that is released from the chemical reaction and all it provides is a little agitation for the acid vinegar.
    I don't think that any other useful chemical is produced by the combination.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 22, 2026
