riven1950's avatar
riven1950
volt amp meter needed
I am looking for a round v / a meter that is compact and sealed in the back except for the wires.
needs to be sealed because I am mounting it through the " wall " of my kayak so a plastic nut on the back would be nice.
Only ones I have found so far are on ebay and shipping from China, probably on a slow boat.
I probably will order two and mount one near the battery / tank monitor. Would that be an ok place to put it.
Thanks in advance
  • Datel makes some high quality panel meters and are made in the US here.. They have a round LED voltmeter but no combination V & A meter and no round ammeter. The model below is "oiltight" and sealed. Has screw terminals on the back but you probably dab some epoxy on them? Datel meters are high quality but not cheap.
    Datel does have small square panel meters tho. The problem with a DC ammeter on 12 VDC is that you likely need a shunt and that will have to be mounted somewhere and they're not small. Some meters also require a 5 VDC power supply to work. It could be hard finding something that is watertight and rated for a moisture location. For example, the Datel meter below is rated IP67.
    But yes, what are you doing in a kayak?
  • Sounds to me like what you need is a battery voltage monitor that is made for a marine application. I would think that any large boat dealer would have one.....and maybe smaller dealers too.
    I STRONGLY encourage you to NOT make any hole to mount it; just glue it in place.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
