gbopp wrote:
Get a multimeter and learn how to use it if you don't already know.
It will give you the actual voltage, Don't depend on the gauge in your RV that gives a vague reading.
My meter plugged into a socket gives quite accurate voltage. Even better, I can check the voltage any time I glance that way rather than pulling out the multimeter and finding a place to take a reading...plus short of going up on the roof to take a reading right at the air/con, it's not going to be significantly different.
To the OP: Yes, voltage does vary both based on what's operating in your RV and what others are running in the park. Typically, low voltage is an issue on busy hot summer weekends when everyone tries to run their air/con at the same time.
As long as it's above 110v, no issues.
Down to around 107v...probably OK but a bit of a gray area.
Below 104v is a no go. Damage is a high probability if it stays at 104v for more than an instant.
There are a variety of devices you can get...some will simply cut power to the RV if it doesn't like what it sees...others will boost voltage (commonly called an autofomer), they will actually take low voltage boost it by around 10-15% and then feed the RV. There are still limits with these devices.
