Ha not using the ac it’s 48 degs out,now the furnace is another story ??
It’s actually in the green but not by much
Mine at home is right at 120
So why would this be different ?
There are TWO breakers in the panel here both are on
Lots of wire between your campsite and the utility company transformer
Other people using power
creates voltage drop,
Ever lived in an old house in an old neighborhood?
Ever used 100 ft of extension cord, to power a power tool
Same thing
Your propane heater uses 12vdc for the blower
As long as your converter is working and the batteries are charged
It will work just fine
The blower uses less than 100w , only around 7 amps of 12vdc power
Portable electric heaters do not work at full heat, if the voltage is low
Fridge will cool better at voltages at or above 110v
Electric heating element does not perform well at low voltages
Should be good at 114v and 48° outside
But not when it's 100° and 100v power
Like I said in another post, I prefer propane for fridge operation
It's also more consistent heat for fridge operation
I actually like 120v compressor driven residential fridge best
But that is another topic
