gypsmjim's avatar
gypsmjim
Walking (crawling) on the roof
2015 Jayco Jay Flight SLX.
I want to put vent covers over the two roof vents. I haven't put a ladder up on the side yet, but I think I can reach them from one. If not, is the roof strong enough for me to climb up on top to do the job?
  • as a rule of thumb no ladder on back not a walkable roof get plywood dispurse your weight
  • You might want to check your manual first. I thought mine seemed a little iffy.
    The manual says not to walk on it.
    Put 1/2" plywood on top first to spread the load.
    I did sit on the edge and kinda lay on it to put my covers on. It seemed fine.
    I'm sure if I stayed right on rafters it would be OK, but I didn't want the old foot thru the ceiling trick.
  • It probably depends on how heavy you are but they had to walk on it to install the roof in the first place so anyone of normal build should be OK.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 28, 2026
