DownTheAvenue
Apr 28, 2019Explorer
hikerboy1 wrote:downtheroad wrote:
I'd go with Goodyear Endurance in the same size except move up to load range D. Les Schwab and Discount Tire can order them for you.
I considered those as well. My rims are stamped "max load 1820 lbs", which is the max load for my load range C tires at 50psi. I'm wondering if it would be OK to go to a D with a 65 psi rating on the wheels?
I wonder if the wheels are stamped with a maximum air pressure? It may well be that your wheels are the limiting factor and upgrading to a greater load capacity tire will be negated by the wheels.
Regarding the 1 star rating for the tires your are considering remember most RV tire failures are caused by overloading, under pressure, over speed, or over age.
Looking for advice before your next adventure? Look no further.25,198 PostsLatest Activity: May 28, 2026
