DSDP_Don
Jun 09, 2015Explorer
Your valve is just a slot with rubber on both sides. Toilet paper and other debris gets caught in the slot when you push the valve closed. The valves are cheap ($13.00) and are easily replaced on most units. Either change the valve out or take a few minutes and clean the slot/groove out with a tool or coat hangar. Also, spraying a little WD40 on the handle shaft helps it move more freely and generally allows you to get the valve closed tighter.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
