no-logic
Aug 05, 2022Explorer
willald wrote:
Here's one more vote for the water bladder, instead of a tote.
Tote would definitely work, but would be more expensive, and be much more of a pain to store and move around when empty than the bladder would. Not to mention the funny looks you'd get from your neighbors when they see you emptying water into your fresh tank from a tote that is typically used for waste water.
I've thought several times of getting one of those water bladders as a way to refill the fresh water tank when we might need to. Might just do it one of these days.
Would you really need a pump to transfer the water over? As long as the water bladder is sitting up higher than your fresh water tank, I'm thinking you might could gravity feed the water into the RV fresh water tank.
If your RV is one that has a switch you can throw that will transfer water into the fresh water tank, and you have a winterizing kit on it, then you could just hook up the bladder (or tote) to where you would normally suck in antifreeze when winterizing, and use the RV pump to bring the water ito the fresh water tankn. Thats probably how I'd do it, if gravity feed didn't work.
Our trailer did not have the capability of pumping into the fresh with the antifreeze pickup. That goes throughout the coach and not into the fresh tank. But I did some plumbing and with a couple of valves added...it dpes now. This is how we filled with our 5 gallon jugs. I think I would prefer a tank instead of a bladder.I think I can deal with the size. And yes, you may be right about the ability to gravity feed. Good thought! Thanks!
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
