machunt
May 28, 2018Explorer
water filters
Whats everyone use for fresh water filtration? we use the standard wal malt single inline filter, seems to work ok, but has to be something better. for outdoor use.
Bierp wrote:
We're about to go full time . . . I had the dealer install a whole house filter . . . They put in an Everpure EV925205 . . . the filters are only rated for 700 gallons. For a whole house system (including laundry and shower) that's going to go by pretty quickly when full-timing.
I expect I'll probably be looking at a more robust system in the near future, but I'd like feedback on the one they did put in.
WTP-GC wrote:Cummins12V98 wrote:
I have plenty of flow even with my WATTS regulator set to 60psi. Something is not right with your setup.
I wondered the same thing as well. I bought an expensive pressure regulator but the gauge never showed greater than 20 PSI on the hose, so I figured that its a faulty unit. So I went back to my old pressure regulator (non-adjustable style) and its preset to 40 PSI. I'm going to replace the expensive one and see if that makes any difference. Without the regulator, I have strong flow. I believe I read that the filter limits flow to 1 GPM.
TechWriter wrote:
I would ditch your current system and do the following:
First, install a whole house, clear single canister sediment filter. This will at least keep the "rocks" out of your system. I suggest a clear filter housing because it's important to see what's going on with your filter. Opaque canisters or Inline filters don't let you see this:
Second, if you have room, install an under-the-sink Reverse Osmosis system for your drinking water.
Bierp wrote:
I appreciate the feedback.
I'll definitely be going with the RO under the sink. As for the sediment canister replacing the Everpure system they gave me, what's the reasoning here? Is it because it is a crappy product, or because I'll go through them too quickly with a 700 gallon rating on a whole-house system, or will it hurt my pressure, or...?
TechWriter wrote:
You'll be going through filters very fast. So weigh the cost of these filters against a standard-size filter that you can clean over and over again.
Bierp wrote:
For the RO 150, is the flow from that adequate to supply a kitchen sink?
Oops! That RO 150 I linked to is not a good choice.
Here's a better choice -- ***Link Removed***. The Watts RO system has a holding tank which you'll need and a separate spigot for the RO water. Watts is a good brand and a 4-stage is just fine.
