- marcsbigfoot20bExplorerFirst and only time I had that problem was crappy well water from campsite and anode rod that looked like a coral reef or Swiss cheese.
Gave it a good flush and a dose of bleach, ran some through and let it soak then tripple flush. - Frank55ExplorerDrained tank earlier this year. I also replace anode rod. Might try another type.
- 3oaksExplorer
downtheroad wrote:
That should do it.
Kunk in the water heater tank. When was the last time you drained it and flushed it out?
Pick up one of these:
And you wouldn't have to drain your fresh water tank, just the water heater tank. - Old-BiscuitExplorer IIIStagnant water in water heater
High iron in water source
Anode rod IF Suburban (Magnesium can react ---swap to aluminum anode rod)
Sulphur water can be caused by a chemical action or by bacteria.
Sanitize water system...including water heater tank - bob213ExplorerIf you have an anode rod made of magnesium it can sometimes react to the minerals in the water you are using giving off a sulfur smell. Your solution will probably work(as well as hydrogen peroxide) but if you continue with the same water supply it will more than likely return. An aluminum/zinc rod may help.
- downtheroadExplorerKunk in the water heater tank. When was the last time you drained it and flushed it out?
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
