JWP127's avatar
JWP127
Water Heater & display
Just bought a Venture Sporttrek Touring 336VRK. During PDI, the water heater worked. While camping for the first time in it, about halfway thru the weekend, when I tried to run the water heater on propane, my display panel fault light came on. It runs fine on electric. Thoughts?
Also, my display showed all tanks were empty during the entire trip. The battery level indicator worked though.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Had the same issue with my Atwood Water heater
    When it was new I'd often have to re-set the Gas side 3-6 times before it would work if starting cold.. If I heated it with electric.. then it would work great. but it had to be warm to start with.
    Finally it refused to work at all on Gas
    Then I put in a new control board and it's been fine since.
    NOTE there are other things that can cause this. Dirty burner oriface. Improper Spark gap (That's a common one) and so on.
    About the only thing I do NOT want to read is "Air in the gas lines" That is **NOT** your problem.... Though ti's a knee jerk reaction for many (The water heater is a major guzzler of propane. it tries 3 times before the fault light comes on. the first try would purge air from the lines if there was any needing purging)
  • Remove control board and pull off the stick on foam spacer, look for what appears to be a burnt spot on underside of PCB in the center. If it has a burnt spot and on top side says Fenwal Made in China that is the culprit. Replace with a Dinosaur board..
  • Sometimes there is no gas in the system also and you may need to turn it off and on 3 or 4 times before it ignites.
  • OEM is a 6 gal gas/electric Suburban water heater
    Red Light coming on .....
    That is Fault light which is triggered when Gas Flame doesn't light OR Prove it lit
    Spark Electrode provides the high voltage spark for ignition AND also is used a pathway for 'flame proving' signal,
    No signal....circuit bd shuts down DC to gas valve so raw fuel doesn't accumulate
    Check that Spark Electrode is 'firing' ---should hear a STRONG CLICK, CLICK, CLICK
    Check that tip of Spark Electrode is ENGULFED in flame when it lights off
