fj12ryder
Jan 15, 2019Explorer III
donn0128 wrote:This had me wondering since I thought I knew how it worked, but you would think the Suburban assistant service manager might be aware, but according to this article from a boating magazine, he is incorrect.
No. According to Suburban the anode rod uses a chemical reaction NOT electrical.
It could be totally isolated from any metal and will still perform its intended function. Think sacrifical anodes on a boat for an example.
"There is an unfortunate misconception that a sacrificial anode can be mounted anywhere, even hung over the side on a string, and it will still perform its appointed duty. That is dead wrong!
For a zinc anode to provide any protection, it must be in electrical contact with the metal being protected. The conductivity of the water is not adequate. We need low-resistance, metal-to-metal contact..."
He refers to zinc as that seems to be the material most commonly used on boats, but the operation is the same.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
