Lon-Str
Sep 28, 2019Explorer
if it is a Suburban, be sure and check the plastic valve between the hot and cold water line at the rear of the unit. On my older Montana you can't actually see it because of the cabinet, so you may have to feel for it. I just spent 337.00 replacing my heater for no reason. may be worth a check.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
