zach477
Sep 01, 2015Explorer
Water hose
I went to use my brand new Camco water hose...not the cheap white one, but the more expensive blue one. The fittings on each end leak. Am I doing something wrong or is this common? Don't know how ...
GMandJM wrote:
The rubber washers are often lost and easily replaced. Just fill your fresh water tank and run off that (with the pump) until you can stop the leaking.
Btw, how was your trip? (Glad to see you arrived safely.)
