zach477
Sep 01, 2015Explorer
Water hose
I went to use my brand new Camco water hose...not the cheap white one, but the more expensive blue one. The fittings on each end leak. Am I doing something wrong or is this common? Don't know how ...
downtheroad wrote:Cummins12V98 wrote:downtheroad wrote:
Make sure these are installed in each end...
That could be the problem they only go on one end.;)
Well, just because I'm bored..The OP did state, "The fittings on each end leak"
So, yes, there is only 1 on the hose, but probably the washer on the inlet side is also missing - so technically he does need to make sure that he has one on each end.
