zach477
Sep 01, 2015Explorer
Water hose
I went to use my brand new Camco water hose...not the cheap white one, but the more expensive blue one. The fittings on each end leak. Am I doing something wrong or is this common? Don't know how ...
"austinjenna".....Simple, just buy a second quick connect, even a plastic one and screw the male quick connect onto your hose and quick connect the ends together for storage.
There are two VERY good reasons for using the quick connect. First, the constant connecting and disconnecting from the RV water inlet, often ruins it over time and you're often fighting leaks. With the quick connect, you can connect it one time, with some pliers and never have a leak.
Since the male quick connect is such a tight mechanical connection to the coach, it better supports a metal 90. The hose is then hanging straight down from the side of the coach with less stress and less of a trip hazard.
