IAMICHABOD
Jan 14, 2016Explorer III
Cummins12V98 wrote:
Those are fine but try coiling when the temps get cool. IMHO these are the best hoses available I have found. NOT cheap but will last a lifetime. You can pick from a variety of lengths or have any length made you want. Also you can select from solid brass or SS ends that won't fall apart.
These hoses are flexible in COLD weather.
Not good with adding links maybe someone can help, thanks.
http://www.rvwaterfilterstore.com/Hoses.htm
Here You Go
And Here is a easy way to make those clickable links. If you can post a URL in a post, it is easy to make it clickable.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 27, 2026
