bob_nestor
May 25, 2015Explorer III
MitchF150 wrote:
When the air is used in a 'hwy' tire, where it's going to warm up and increase in temp, any moisture in the tire is likely to evaporate and be a none issue.. A tire pumped up and never warmed up could have moisture build up and have the issue you had.
No conspiracy against you.. Just physics. ;)
Mitch
I'm wondering where the moisture can evaporate to in a closed environment like a tire. Evaporation just turns the water into a gas that is absorbed by the air at higher temps, but what happens with the temps fall? Doesn't the water vapor condense back into water? Or am I not remembering my HS physics and meteorology correctly?
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
