bukhrn
May 25, 2015Nomad
cbshoestring wrote:Can't help you with the water problem, but when my front tires got dry rotted that bad, instead of buying new Tires, I just went to Agri-Supply, and bought inner tubes for them, approx. $4.00 each, no more problem.
This is not an RVing issue, just something that is making me go :h
My front tires on the riding mower had gotten pretty dry-rotted. The Toro 8-32 is a 1987 (that I bought in 2008ish) and the tires may have been original equipment. The one was failing to hold air, so I figured it was high time to replace them...$18.00 a piece at Walmart. I am such a big spender.
AnyWHO... I cut the flat tire off the rim, then turned my attention to the one that held air. When I cut it off the rim, approximately one cup of water came spewing out.
HOW did that water get in there?????? I have never had that tire off the rim. It was properly inflated.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
