dcmac214
May 25, 2015Explorer
cbshoestring wrote:
Can't see needing traction on front tires.
Will definately be checking my compressor.
You're obviously not a farm boy! Our tractors often pull things that drag, and drag hard. As-is tractor weight is too often not enough to give the tires the grip they need to pull implements. The fix is to somehow add weight to the axles. Water & other liquids in the tires works pretty good (with accepted problems at tire changing time). Axle extensions with steel weights work godd but the added width could be a problem. Most common these days is additional weights hung on tractor frame.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
