wgriswold
May 28, 2019Explorer
Water Leak
I have a leak that I can't figure out. The area under the sink, where the low point drains are, is getting wet. In March the trailer went to the dealer to fix this and the low point drain valves and a...
midnightsadie wrote:
when I hunt for a leak I use a paper towel rub around the area then check towel for a wet spot.works better than a hand ,
