schlep1967
Oct 05, 2020Nomad
The only thing I can think of that would turn your water brown over time would be rust. And if it rusted once it will continue to rust. You need to find out if you have a steel fitting going into your water heater and get rid of it. If not that I would try contacting suburban with your information/serial number for your water heater and ask them what might be causing the problem. They may have had a run of bad stainless or wrong welding rods used when putting together the burner tube.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
