wopachop
Oct 06, 2020Explorer
pasusan wrote:Shop vacs come in handy. I used a 2 foot piece of hose to vacuum out the propane heating section. Wiped the hose clean and then vacuumed out the water and white deposits in the water heater.
Thanks all for more info...
BB_TX - when winterizing I've been getting that last bottom water out with paper towels - slowly but surely - will look into that pump or see if we have something around that would work.
I have tried to use water pressure to push those white deposits out. Water pressure alone wont get them all. Proof is when i empty the shop vac. Its able to suck out debris that water pressure couldnt force out because the drain hole is too high on the tank.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
