jstaffon's avatar
jstaffon
Water pressure and flow regulator question
I have the typical pressure regulator for my city water connection on my 2016 Rockwood 5th wheel. It is marked to regulate to 40 - 50 psi. I also noted that there is a plastic water flow restrictor inside on the downstream side of the regulator that can not be removed. It has an outlet hole about 1/4" in diameter. This restricts the flow inside the camper too much. I also have a gauge and know the water pressure is around 40 psi. I'm considering drilling out the restriction to something more realistic. I'm very water conscious and don't waste water when showering, etc but It's important to have enough flow to flush the toilet correctly. Does anyone know if drilling out that plastic restrictor may have unintended consequences? Thanks in advance!
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
