DutchmenSport
Feb 13, 2017Explorer
Unless your's is different, I've never heard of an RV toilet needing water pressure to flush it. You either push slightly on the peddle with your toe and it fills the bowl. Or you lift with your tow slightly and it fills the bowl. Once fill, you push the peddle down and it empties, usually just straight down into the holding tank.
Shower head also have restrictions on them preventing the full pressure to be felt. Before making any changes, remove the head off your shower and see how fast the water is running. You may be just fine getting a different shower head.
I don't know about your regulator, but before messing with it, how about adding water to your fresh water tank and try running water and taking a shower using the water from there. See how much your water pump is putting out. Your water pump will not exceed the pressure for your plumbing pipes. But outside city water can ... very easily. If the on-board pump performs better, you might consider just getting a new regulator rather than messing with the existing one and setting up for failure.
(I think I ready your post correct)... the "down stream" regulator is NOT in your camper plumbing is it?
FYI, I quit dealing with the question of water pressure and regulation. I simply fill my fresh water tank and use my on-board water pump. Been doing this for years. When the tank nears empty, I simply fill again and put the garden hose aside. Never have to worry about water pressure this way.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
