Lynnmor
Aug 26, 2015Explorer II
OkSixpack wrote:Lynnmor wrote:
After connecting the water and turning on the water heater the pressure might rise in the RV if you use no water. It is possible that the regulator didn't fail. The regulator has no way of bleeding off excess pressure downstream.
Shouldn't the pop off valve on the water heater relieve excess pressure?
Jim
Sure, that'll work. The T&P valve will relieve at 150 PSI.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
