theoldwizard1's avatar
theoldwizard1
Explorer II
May 31, 2017
Water pressure regulator
When my daughter's family bought a RV last year, they bought a (rather expensive) surge protector and a water pressure regulator. The surge protector does not "turn on" until it see several minutes of constant voltage, which will catch you unless you remember this. The pressure regulator result in low volume/pressure at the faucets inside.
I can kind of understand the surge protector but I never used a water pressure regulator back when I was an active camper.
How many do or do NOT use a water pressure regulator ?
Are there good ones that do not result in low volume/pressure ?
  • I suspect you have a restricted faucet not a pressure problem. Remember that pressure and volume are two different things. You can have high volume with low pressure and visa versa. An "expensive" regulator should not affect volume. Pipe obstructions are the cause of low flow, if the source has good volume.
    Check the screens on the regulator, inlets, and faucets.
    If your flow is restricted with both the fresh tank pump and street spigot then it is likely inside faucets. If it is only restricted with the street supply and regulator then it is likely the screens in the hose or regulator to the RV.
  • My previous used RV came with a nice looking but unbranded brass pressure regulator that SERIOUSLY lowered pressure and volume. After suffering with that for several trips I bought a similar looking Camco brand from Amazon and the problem was gone! Looking inside both, the unbranded one seemed to have much smaller passages for water to pass through. It certainly would have protected my RV plumbing but with aggravating results! Not all regulators are the same although they may look similar.
  • I use a vaterra pressure reg, I had a white rv hose swell up so much I thought the hose ate a rabbit
