Old-Biscuit wrote:
Pre-set ones tend to be more restrictive and limit flow
Adjustable ones have higher flow ratings
Personally I use an adjustable set to 50#.......fill my fresh water tank and exclusively run off of pump. Constant pressure and flow regardless of where we go.
PLUS I don't have to worry/deal with a 'flood' like the one that happened in 2008 when on city water with regulator and fitting gave way while we were sleeping .....flooded the RV to the tune of $6000 in repairs/costs
No more city water hook up for us.
Fill tank use pump and with just a flip of the pump switch turn it off at night or whenever leaving RV evn when just gong outside......SIMPLE
THE best way to regulate water is to work off from water pump only. Search water damage on here, you'll understand why. On annual check list... test with air 80 percent of what your OEM spec is.
