portscanner
Jun 12, 2014Explorer
The water pump wont turn off because the pressure is low (because there is no water to be pumped from your fresh water tank)
Why do you think it emptied out the low point drain valves? Did someone open them? If so, close them, refill your tank and go back to having fun.
Or could have someone left the tap open in the kitchen sink or bathroom and now all your freshwater has been pumped into your greywater tank? What do your indicators say as to the state of your grey and black tanks? Are they full?
Could you have a leak somewhere? Check under the sinks for water, and if you have a basement, check in there for water.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
