Vulcaneer
Jun 12, 2014Explorer
Probably a leak somewhere. If parked on grass/gravel you might not notice it. Park it on pavement and fill the FW tank and start the pump. After a while you should see a puddle. The water will fill the underbelly and eventually leak out of there. You may be able to drop the underbelly to see where the leak is.
If the pump stops when the system has water in it, then it is likely not leaking. But if the system is not full of water, there is air in it. And the pump will continue running. It cannot build enough pressure to auto shut off, if it is pumping air.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
