Bucky_Badger
Jun 12, 2014Explorer
Shipdoggg wrote:
To clarify, every time we turn on the pump and run the faucet, water comes out the low point drain valve in the rear (under tub). Not we plugged the drain to elimate grey water possibility. So that is why we are losing so much water.
You need to tighten the fitting/change out the valve so water pressure does not push water out the low point drain
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
