azrving
Jul 01, 2017Explorer
It's leaking somewhere or the pump is leaking internally back to the tank. It only takes a very slow drip. My sons FW was leaking very slightly at the low point drains and the pressure side of the pump dump valve. I replaced the o rings in all three valves and problem solved. I have run his pump then shut it off and turned it on a week later and it didn't cycle.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
