esox07
Jul 01, 2017Explorer
OK, thanks. I didn't think of the pump itself allowing backflow to the tank. That makes sense. I will try running a full tank of water to see if that helps. It does seem that at times the pump doesn't cycle or very rarely cycles without water being used...so maybe the "check valve" is allowing some backflow at times due to debris being trapped.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
