Stranger
Oct 16, 2018Explorer
mobeewan wrote:
The only time I have ever had a problem drawing water from the water tank below the floor or from the jug of antifreeze when winterizing was due to a joint upstream of the pump leaking and drawing air not allowing the pump to pull the liquid.
Once I tightened the hose clamps or retaped the joints the pump pulled the liquid fine.
Don't forget to retighten the strainer bowel too.
We just came back from dry camping for 3 days,water pump on continuously for the ice maker. Cycled normally. On during use, off when taps closed.
Teflon taped pump inlet and adapter valve threads, also the strainer's male threads.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
