Stranger's avatar
Stranger
Water pump won't pull Antifreeze from the jug.
Tried winterizing today. Got the Camco Water pump converter kit. Water pump won't pull Antifreeze from the jug.
Shurflo pump.
Any ideas, tips.
Thanks.
  • jrs1871 wrote:
    Since we don't use the water pump a lot, we always have to prime it when we winterize. Get a small funnel and pour antifreeze into the intake tube while running the pump. After you have antifreeze going through the pump, put the intake tube into the jug. It takes a bit, but has always worked for us.
    this is what I have to do to one of our TT's
  • Since we don't use the water pump a lot, we always have to prime it when we winterize. Get a small funnel and pour antifreeze into the intake tube while running the pump. After you have antifreeze going through the pump, put the intake tube into the jug. It takes a bit, but has always worked for us.
  • you did put it on the input side of the pump? do to design/construction I had to mount mine on the output side and then used a boat bilge pump to force AF in. and of course you had the valve turned the correct way?
    bumpy
  • When you turned the pump on did you have a faucet open? You have to have a faucet open in order for it to work.
  • Stupid question...do you have the valves lined up correctly (line from fw tank closed, line from jug open), and are the low point drains closed?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
