I have the campco water regulator. First time I used it no problem. Since then we get horrible water pressure. I take it off when we shower then put it back on. Is it just because it's a cheap 10$ reg...
Buy a real one, with a gauge and adjustable. Not that much more, and well worth it. Another trick if you have water in your fresh tank is to turn on the water pump while showering. Usually will double your pressure at the shower head.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
