Cdaddy wrote:
I have the campco water regulator. First time I used it no problem. Since then we get horrible water pressure. I take it off when we shower then put it back on. Is it just because it's a cheap 10$ regulator or something I could do about it.
Yes. that is the problem.. The unit has not the capacity for a shower
There are several water regulators.. here is a list
The standard ones a 3/4" (roughly) cylinder with hose fittings on the ends part of the body.. JUNK openings inside are too small and can not pass 2GPM less there is over 100 PSI behind it.
"High Flow" or "HIgh Capacity" like above but with a bright plastic grip on the female end or wings on the plastic body to make it easier to tighten onto the high pressure source.   A little bit better but .. See above.
Valterra adjustable: I have not tried this one but others give it good reviews.
Watts or Zurin (i've tried both) Mine are 3/4". but 1/2" should be enough.. (The 3/4 was cheaper when I got the Zurin)
When new these are fantastic.. I hooked the ZURIN up and opened the outside shower... Needle on my pressure gauge acted like it was welded to the 50PSI mark  Did not even wiggle.
Same with the Watts when it was new.. But after a decade it was getting kind of long in the tooth and had regulation issues as well (Pressure dropped big time)
Both Watts and Zurin are rebulidable..
I also have a Sur-Flow.. When New I'd give it a 9, (not qu9ite as good as the Watts/Zurin) it also is 10 years or more old and loosing capacity. I believe it too is rebuildable but have not searched for Rebuiold kits yet.
NOTE The Zurin with hose adapters set me back over $60.00 and worth it. Got it at a Plumbing Supply
Some Camping Worlds and othe rRV owners have a half inch or there about Watts,, Often with pressure gauge, in a bag with hose adapters, sometimes pre-instilled.. It is not a catalog item at CW but a manager's item (Only selected stores have it) But any plumbing supply should have wither Watts or Zurin.
