TucsonJim
May 29, 2014Explorer II
Typically, there is no valve.
1. Turn your water pump switch on.
2. Do you hear the pump running?
3. Open the cold water valve on the kitchen sink.
4. Do you hear the pump running now?
My initial suspicion is your pump is not activating, and you might have a fuse that needs replacing. You could also have air in the water lines that you need to bleed off before pressure will build up and water will flow.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 26, 2026
