prichardson
May 29, 2014Explorer
Do you hear the pump run? If no it is an electrical problem - blown fuse maybe.
if yes could be a couple of things. Some units have a valve near the pump to switch between the tank and a pickup tube for winterizing. Check for the correct position. Or the pump may not be priming - open a faucet to get air out of the lines until the pump primes. Could be other things but these should be a starting point.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 26, 2026
