Pool's avatar
Pool
WD front end is light
After a few trips and weights I feel I need to adjust more weight to the front. (actually drops 60 lbs in the front with TT) driving into the wind shifts the truck around in the lane quite a bit. Suspension has been upgraded with new ball joints and shocks. Front rating is 3600lbs and weighing in at 3100 with TT. Which method gets better result for a fastway e2 hitch. Adding washers to tilt the head or raising the bars up a notch. as I have read the bars are supposed to be level With the frame as they are now so maybe adding washers is the next adjustment.
