BarneyS
Sep 25, 2014Nomad
mkirsch wrote:SC camper wrote:
I see what you mean about using a right handed sway bar on the left. Turn it upside down, remove the part that attaches to the hitch and turn it back over. The handle will be on the outside but will be upside down.
They do make left handed sway bars.
http://www.amazon.com/Husky-37498-Handed-Adjustable-Control/dp/B004RCPBUQ
Why you making it so complicated? Just swap it end for end. The balls are the same on both ends.
Not quite. The ball sockets on each end of the sway bar are rotated 90 degrees from each other. SC camper is correct.
Barney
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
