SC_camper's avatar
SC_camper
WDH adjustments after hitting scales
We took delivery of our 2013 Dutchmen 261BHS Friday. We loaded it with almost everything we had in the old camper while at the dealer. The Dutchmen came with a Huskey 800-1000lb WDH. It must have been used with a 4x4 because it was 8 inches to low. We flipped the shank and adjusted it with a tape measure and the old "eyeballing it" method. We left from the dealers lot for our first weekend trip. On the way home I hit the scales.
With the current setup, the TT is 1 inch higher in the front than the back, The front axle of TV is the same height and the rear dropped 1 1/4 inches. Making the TV level front and rear. The weight bars are pointed slightly up towards the frame. Using the 6th link.
TV without TT, Steer axle 3500
Drive axle 3860
Total 7360
TV with TT and WDH, Steer axle 3520
Drive axle 4660
TT axle 6620
Total 14800
I think the numbers look good, but need to drop the ball height.
What do ya think?
How critical is it to have the WD bars level with the TT frame?
Is the tongue weight 800lbs?
  • AFAIK no such thing as a "left hand" sway bar.
    You just put a "right hand" sway bar on "backwards" so the lever is facing out.
  • Thanks for all the input.
    If I tilt the head, do I need a special washer or can I use one from hardware store that is the same size?
    I would like to add a second friction sway bar. Is it real important to get a left hand one or will a right side work? I think the tightening lever will be between the frame and sway bar. Will it hit or just be a bit inconvenient?
  • I agree with most of the above. Drop the ball one notch, add one washer. Also, can you move the bracket a little toward the front to straighten the chains? I pull one of a similar size to yours with that same hitch and use two sway bars as well as 1400# bars. It sits almost perfectly level to the truck, slightly nose down. Pulls great.
    What do ya think?
    Yes, the numbers look good. And, it would be good to drop the hitch head.
    As Barney stated, it is not necessary for the WD bars to be parallel to the TT's frame as long as the bars cannot contact the frame when turning.
    The indicated tongue weight is approximately 1060# with 240# being transferred to the TT's axles.
    Ron
  • Your numbers look good to me and the bars look ok also. You have 6 links under tension which is good and the bars are just slightly off level.
    As long as the chains don't crash into the snap up brackets during turns (and they shouldn't based on what I see) you should not have to make any farther adjustments in my opinion except to lower the hitch head one hole to level the trailer.
    If you decide to tilt the hitch head to level and lower the ends of the bars you are probably going to have to use 7 links under tension or you will have too much weight transfer taking place. Nothing wrong with that either.
    Barney
  • Drop the hitch head one hole on the shank and adjust the angle back one notch to help level the bars.
