Merlisk's avatar
Merlisk
WDH needed?
Is a WDH always needed?
I just recently changed out my TV from an F-150 to an F-250, 4x4 CC, 6.7L diesel. The GVWR of my TT is 7650 lbs. According to the Ford site, this TV can tow up to 8,500 lbs without a WDH. But, I know there's more to it than that.
The unloaded front wheel fender: 40 5/8"
The unloaded rear wheel fender: 41.125"
The loaded front wheel fender: 41"
The loaded rear wheel fender: 39.75"
Assuming the TT is level after hooking up, do the numbers above warrant using a WDH?
Thanks.
  • We tow a similar sized TT with an F-250. I can't possibly imagine towing without a WDH as far as sway and handling goes. The thing that will force you into one is the weight carrying capacity of the receiver as pointed out above.
    I towed all last season without the cam arms installed on our Reese WDH. Finally just installed them and have been out once this year. Major improvement with them installed. I'd go with a WDH with integral sway control.
  • Ron Gratz wrote:
    According to Hitch Receiver Weight Capacity (bottom of page 28),
    the tongue weight for your truck is limited to 850# without a WDH.
    If your loaded trailer weight is 7000#, its tongue weight might be in the range of 900-1050#.
    I would use a WDH.
    Ron
    Thank you, Ron. Good catch.
    I looked at that exact chart and only pulled out the 8500 lbs. I should've kept scanning to the right. :)
  • bikendan wrote:
    Your truck's owners manual should have the necessary information. :S
    I didn't find any specs for allowable "weight-carrying" versus "weight-distributing" trailer weights or tongue weights in the 2015 owner's manual.
    The only place I found that information was in the Towing Guide.
    I was at a Ford dealer a couple days ago and noted that only the 2015 Super Duty trucks have weight limits posted on the receiver.
    The F-150s did not have a weight sticker on their receiver.
    Ron
    I would use a WDH.
    Ron
    I agree with Ron. The weight limits of your trucks hitch dictate whether you need a WDH or not.
  • Your truck's owners manual should have the necessary information. :S
    I would use a WDH.
    Ron
  • You can run without a WD hitch. I am running my PUP and Minivan combo without one and everything is in spec... I do use a sway bar.. I highly recommend it.
    Just make sure your draw bar and Hitch is rated to carry the weight.
    Then you can weld on two sway bar tabs so that you can run DUAL friction sway control with your trailer. (If its over 26 ft)
    Here is what I am talking about..
    This forged draw bar is rated for 1,600 lbs of tongue weight and 16,000 lb trailer weight.. It is much stouter than a regular draw bar.
    Then you will need a few of these tabs and weld them to the draw bar, one on either side.
    I would imagine that your rig will tow great as long as the receiver and the draw bar are in spec.
    Thanks!
    Jeremiah
  • Sandia Man wrote:
    Although our truck can handle our 32' TT, our WDH has integrated sway control (SC) and I wouldn't get on the interstates without it with the kind of winds we have to deal with here in the four corner states where we camp most often. Just returned from a 2 week trip and had to drive home through 30+ mph winds with gusts higher than that and thankfully our WDH with integrated SC kept us straight and on the road throughout. Takes us just a couple of minutes to implement with our power tongue jack.
    The sway bar is separate on mine, and I agree, I wouldn't leave home without it. That should be in a commercial or something. :)
  • Although our truck can handle our 32' TT, our WDH has integrated sway control (SC) and I wouldn't get on the interstates without it with the kind of winds we have to deal with here in the four corner states where we camp most often. Just returned from a 2 week trip and had to drive home through 30+ mph winds with gusts higher than that and thankfully our WDH with integrated SC kept us straight and on the road throughout. Takes us just a couple of minutes to implement with our power tongue jack.
  • This link seems to say a WDH is needed:
    When Is Weight Distribution Needed?
    You would likely benefit from a weight-distribution system if:
    - Your trailer weight (GTW) is more than 50 percent of your vehicle's weight (GVWR)
    The GVWR of my TV is 10,000. I estimate my TT weight to be 6,500 max. That's more than half, though.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
