4aSong
Mar 07, 2017Explorer
I would also recommend the lock-nuts and/or grade 8 nuts with loctite.
I have a question, I have a spare set of round bars rated at 800lbs which I would like to alter by adding chains to use with my E-Z Lift hitch system, I plan on drilling two holes in each bar for U-Bolts and adding chain, is there a certain type of hardened chain and u-bolts that I should be shopping for, as DD716TED stated above there is a considerable amount of pressure on the u-bolt / chain.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
