Ron_Gratz
Apr 20, 2015Explorer
spoon059 wrote:The important thing is to get the front-axle load correct -- then, the rear axle load will take care of itself.
I guess my point is, I don't understand the effect of air bags on a WDH. It seems that either way you do it, the bags are still putting more weight on the rear axle, which therefore reduces weight on the front axle.
One thing is certain -- if the WDH is adjusted first and then the air suspension is allowed to raise the rear of the TV, the lifting of the rear will cause a reduction of the load transfer to the front axle.
If the TV's "air suspension" system is designed to keep only the rear end at a constant ride height, then one way to use the WDH in conjunction with air suspension is to:
1) adjust the WDH so the front-axle load is slightly greater than the unhitched value, then
2) allow the air suspension to raise the rear -- causing the load on the front end to be reduced.
If the WDH was initially "over adjusted" by the correct amount, activation of the air suspension will cause the front-end load to be reduced to the desired amount. This might require some trial and error adjustment of the WDH.
Ron
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
